NMC_EXP
- 12
- 0
- Raton, New Mexico
Decided to clean the CDR valve on my M1009. Removed the oil fill tube to CDR hose at the CDR end and some oil ran out of the hose. There was oil in the CDR valve itself. Probably a shot glass full total.
How does oil get all the way up there? (I have a bad feeling about this).
Other questions:
After I cleaned the CDR with hot soapy water I found that I could blow thru it from both ends with no restriction. Is this valve stuck open or is it supposed to be that way?
Whats with all of the side plumbing on the oil fill tube? Looks like there is more there than just a place to add oil to the crankcase and vent to the CDR.
I cleaned the oil fill cap with hot soapy water also. Afterwards I could see a thin sheet metal disk in the cap which was free to move up and down. The cap won't hold water so it is vented - don't know if it's supposed to be that way or if it's busted?
Jim
Other questions:
Jim
