- 88
- 4
- 8
- Arlington, Virginia
Question: is it possible to pull the engine oil pan without completely pulling the engine? Was thinking of removing front mounts, jack shaft, transmission cover. Your thoughts? Thanks
You just put this to mess with us, right?Question: is it possible to pull the engine oil pan without completely pulling the engine? Was thinking of removing front mounts, jack shaft, transmission cover. Your thoughts? Thanks
