jimm1009
- 70
- 48
- Louisville, KY
A while back I picked up my truck and the oil pressure was pegged out to the max side.
When you turn power on the gauge is at Zero. When the engine is started, it eventually goes to about 60 psi or so and the pegs out.
In my trouble shooting, I pulled the instrument panel down to check the wiring for looseness and correct installation. I cleaned and checked the ground. I checked the connection at the sending unit. No obvious problems were found.
I installed a temporary power wire from the transmitter unit to the gauge. No changes there so I installed a temporary ground wire next and still no changes. Well, most of the time when this happens in a system with and electric transmitter, the transmitter is then considered to be bad or inaccurate so I ordered a new one from one of our dealers / members.
I ordered and received what the parts manuals stated that I needed.
I installed the new transmitter and the problem still exists...nothing changed.
I have a question about my new unit. It is not marked with any numbers as is the old unit. Further more, it is slightly different from the old one that is marked with the MS part number. the connection on the new one is on center with the threads which is on center with the body of the unit. The old unit has the connection off center with the threads and the center of the body. I know that this is not of real concern due to the fact that this unit is new and it could be a design change or simply an upgrade or a different manufacturer.
Attached is a PDF picture of the unit. The one on the left is the old, original unit as delivered by Uncle Sam and the one on the right is not the new one but is exactly the same size and appearance but a 60 psi unit for an M38 jeep. I used it for the comparision picture due to the actual new unit being installed in the engine.
The engine oil pressure still pegs out to the max side. I have not checked the system with a mechanical pressure gauge because it is hard to find one for 120 psi in the generic automotive parts houses. I will do that next but in the mean time, help.. I've fallen and I can't get up! Is there any possibility that this is the wrong new unit since there are not markings or labels installed on it? I have to ask since it is a small possibility.
Jim
Jim
