[2]
Hi there
I have a problem with my M36A2.
To start it goes fine, runs good, I can drive it for about 7 miles, than the engine stalls and I have to wait about half an hour (to cool down?) to get it started again. Then again it runs for another 7 miles or so before it stalls again.
On march 12 we had a nightrun with our MV club. It ran fine and after the drive I left it at the garage where we started the drive because the truck needed it's yearly inspection (MOT). After about 2 weeks I got it back and since then the problems started. I first checked the fueltank and noticed some leaves swimming in there. So I emptyed the tank, removed it from the truck, took out the pump, cleaned the inside. In the tank I found a rag (like a strong paper towel), some oak-leaves, a few tie-ribs and some other debries. I reckon somebody wanted to be funny..
Okay, with a rag inside the tank I understand it is not running long, just until the pump sucks up the rag. Now all the junk is removed, cleaned the inside of the tank, mounted a magnet under the tank, away from the pump, just in case. I cleaned the fuel filters as well. I also mounted a good lock on the fillingcap. Still the truck is not running correctly, just for about 7-8 miles.
The engine is a White MultiFuel Turbo, did only about 9000 miles, Usually runs fine without any problems.
I've been told that sometimes the fuel is too thin so I put in extra engine oil in the fuel tank, about 2 gallons. that should help but it doesn't
Do you have any idea where to look for?
[/2]
Hi there
[/2]
