engine type
SETOYOTA
450
georgia
You can identify the 6.2L engine by looking at the rear of the engine block, between the cylinder heads. Locate the oil pump/tachometer drive mount bolt on the top of the engine. If the bolt is on the left-hand side of the oil pump/tachometer drive, and there’s no turbocharger mount casting in front of the oil pump/tachometer drive, you’ve got a 6.2L engine.
And you can identify the 6.5L detuned engine by looking for the mount bolt on the
right-hand side of the oil pump/tachometer drive. You’ll see the turbocharger mount casting in front of the oil pump/tachometer drive.
stolen from the internet
ken
25
Houston Texas
If the sticker is still there you can tell by looking at the drivers side valve cover. If it is a 6.2 it will say detriot diesel. If it is a 6.5 it will say General Engine Products. If the white sticker is missing you can look at the front of the engine block right where the passenger side cylinder head mounts. If it is a 6.2 it will say "6.2D" . if not it is a 6.5.
JMP308
BIXBY,OKLAHOMA
thanks for the help
thanks for the info ,I will pass on any info I stumble across, I am an aircraft mechanic with lots of work on recip, and turbine engines ,compressors, gear boxes,bearings, brakes, hydraulics and pneumatics &ect--cant seam to get to work on my hmmwv ,trailer , and diesel Kawasaki ,tooo many honey doos, and yard work maybe in the fall :mrgreen::mad:
