Fan Clutch Air Control Valve
Shotgun
9
Dewey AZ
I just replaced my Engine Fan Clutch Air Control Valve with a new one from Erik's (by the way great service again from him), is there a rebuild kit for the old one? I take it, the temp. control piston went out on on it? Don't want to throw it out if it can be rebuilt. Thanks Greg
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Thanks for the web link, that was very helpful. I will give it a try and rebuild it. Shotgun
Or go to a horton style thermal solenoid unit. It threads into the housing the Same but allows for temperature setting adjustments as well as a manual override switch for the fan clutch.
Sent from my SM-G935P using Tapatalk
Shotgun
9
Dewey AZ
Were do I find one those at? Does the manual over ride mean I could have the fan turn all the time if the thermal solenoid unit went out? Having a spare new would be nice. I had the unit go out while I was 6 wheeling in the boonies and the truck was over heating, (Of course it is middle of summer here in AZ, so no surprise by that) finally got to where the trail was sorta smooth enough to run faster and out of 6 wheel drive. Finally cooled off enough by getting some air flow going into the radiator. Tried putting in the two spare fan bolts that are on top, but the fan just spun one out and the other was backing out. The truck sounded like i was killing cats by the time I turned the engine off. Got out to the pavement and was able to run it at 55 no problem back home. Thanks again for the help, Shotgun
simp5782
9,339
Mason, TN
http://catalog.hortonww.com/catalog/pneu_thermal_switch.asp
Just choose the temp you want. Order thru amazon, ebay or your local truck parts store. The manual override allows full time or off control as well as thermal. I have mine setup so i can keep it turned off on pulling hills and turn it on when needed.
If you have an 8.3l engine you just need a #6 jic to #6 jic so you can hook the two air lines together to bypass the stutterstat. On an NHC250 engine its a #6 to #5 jic. Yes a #5 jic is rare.
Shotgun
9
Dewey AZ
Thanks for the link and help. So besides connecting the air lines together, it is only two line 24 volt positive /negative to a switch and then to the battery from what I can tell from the diagrams? Greg
simp5782
9,339
Mason, TN
Power from battery to a dash mounted switch. Then wire from the solenoid to the switch acc plug then ground the solenoid. Mine is up on the upper hose and mounting bracket.
https://youtu.be/_ufRo6qt1Rg
