wyocommo
- 6
- 8
- Casper, WY
Spent the afternoon troubleshooting why the fan clutch does not engage at proper temp. Clutch is working as advertised when air is removed.
When power is removed from quick exhaust solenoid it does not exhaust air in the clutch circuit to allow the clutch to engage.
Dismantled solenoid and cleaned, appears to be OK.
Reinstalled but no joy. If engine is stopped and air system pressure begins to bleed off it will eventually exhaust as it should.
My conclusion is either a bad solenoid, which it sure doesn't look bad, or way too much pressure on the wet tank output air circuit.
Could not locate the specified pressure required out of the protection regulator on the wet tank.
Does anyone know what the protection regulator pressure output should be???
I did a quick disassembly on the regulator and it appeared OK.
