FilterFuge FF25LE
42willys
cherry valley ca
Just got a used one today and after about 30min in 5gals of black oil i thought their would be some build up. checked and the centrifuge was still clean as can be?
Im running at .5 gal per min at 140psi. I cant find a manual on this thing.
also should the black oil turn golden again? im gona let it run all night and check it in the am.
after about 6 hours it was a dark gray color and not pitch black.
Tlauden
Halifax Pennsylvania
Never done it myself but from what i have read on here it will never be its original color again. I would say run it until your comfortable with the outcome, maybe dip a pretty powerfull magnet in the filtered oil and see if you get any metal, or get a sock filter for a final filter.
PsycoBob
11
Auburn, NY
You'll get it lighter than 'diesel-soot black' but not as clean as new.
I run my 2.5gpm system for 24 hours, then clean it. Repeat until you have a clean enough bowl to be happy. Other than power usage & a little wear, there's no reason you can't run it longer & see how much you can get out, especially for a first batch. My bowl is about 1/3 the surface area of a 2-liter soda bottle. Some 45-50 gallon batches coat it only 1/4" thick, others... eew. One batch filled the rotor with jelly- twice!
