First oil and fuel filter change on M812 NHC 250 Cummins
armytruckdiesel
Does anyone know what fuel filters and oil filters I need to buy for my M812? I want to replace all fuel and oil filters on the truck. If anyone has a cross reference chart for napa, baldwin, wix, etc. filters I would appreciate it.
Any tips or things to look for while changing the oil or fuel filter on this model?
Thanks again for your help,
Andy
AMGeneral
115
Connelly Springs, NC
Oil and fuel filters
The filter #'s are
Baldwin oil P999
Baldwin fuel PF316
Fleetguard oil LF516
Fleetguard fuel FS1201 or FS19553(upgrade)
Fill the fuel canister with clean fuel before installing it on the base.
hope this helps.
derby
10
S.E. MI.
RE: Oil and fuel filters
Call Memphis Equipment,they have a filter kit including oil,air and fuel filter.I think it was $125. also dont forget to check the inlet strainer in the injection pump.it is under the large flat head screwdriver slot at the top rear of your injection pump.make shure it is very clean before you remove it!
