Flex plate/fly wheel
Maineguy10
Lincoln, Maine
I have an 85 cucv blazer with a th400, I just got a new flywheel from eBay, it bolts right up, tooth count is right, it's on the right way, all the holes line up, but it is too close to the engine. The starter gear is always engaged, it won't back away from the flywheel and the dust cover over the flex plate won't go on cause it's against the fly wheel. Can anyone tell me what I am doing wrong? Or do I just have the wrong part???
Thanks for the help!
Maineguy10
Lincoln, Maine
I haven't touched that? I took the tranny out, put the new flex plate on, and reassembled. Of course I figured out this problem way to late.......
Maineguy10
Lincoln, Maine
That's what I'm thinking, but Im in contact with the outfit I got it from. So hopefully we'll figure it out sooner than later,
Thanks for the help.
cpf240
Free in Northern Idaho
Sorry, was being a bit silly, hence the smiley face...
How was the part described in the auction info? Did it specify 6.2l diesel w/TH400 trans? I know the 700 trans is supposed to bolt up to the 6.2l, but I don't know if there is a difference in the flex plate between the 6.2l and the 5.7l, etc.
doghead
4 Star General /Moderator
1,175
NY
What part number part, did you install?
14077157 is the GM part number. Lots of threads here on them(search 14077157).
Maineguy10
Lincoln, Maine
Missed the smiley, sorry. Auction info said it was for a 6.2 w a th 400. The seller is in contact with me and says there is only one option for that combo.
DogHead. It's a pioneer auto industries FRA -142
doghead
1,175
NY
Are you sure your starter is not stuck out (engaged)?
doghead
1,175
NY
Can you try to take a few pictures and post them?
Are you 100% sure that your torque converter is properly engaged into the pump?
Maineguy10
Lincoln, Maine
I'm not 100% sure of anything right now. How would I know if it's engaged or not?? I'm learning as I go here.....taking my time, but obviously not enough.
doghead
1,175
NY
Did you pull the transmission bellhousing to the motor with bolts, or did it slide right into place by hand easy?
doghead
1,175
NY
When you install the torque converter into the front of the transmission, there were 2 slots that must engage into the transmission pump. You should have rotated the torque converter and lightly pushed it into the transmission until it "pops" into the pump engagement slots.
If you did not do this, and you forced the bell housing to the motor,that is probably your issue. (your torque converter would be about 3/8" "forward" of where it should be.
If so, you most likely have bent the new flex plate and damaged your transmission pump.
