Flip wheels or cut axle? M105a2
Thunder in NWOR
Northwest Oregon
I have a project in which I need at least 64 inches between the wheels, instead of the stock 57 inches.
Can I just flip the 9.00-20 wheels (w/ndt tread) on the M105A2 trailer axle (i.e., is doing that problematic??), or should I just bite the bullet and cut/lengthen the axle...??
Thanks for comments, Mark
gringeltaube
Staff Member
2,479
Montevideo/Uruguay
How close would m34/ m135 wheels get you?
Not even halfway.... just gaining two inches that way, not seven as desired.
If this was for something permanent I would simply disassemble, flip and reweld the centers of the original wheels, either style - riveted or welded.
That would bring about 9" wider track.
It has been done... see dimensions, here.
G.
