flu419 ign. sw.
troll
Verona,VA
The ignition switch fell down inside the dash- how do I access the area behind and below the speedometer, etc.? The key and retaining nut are still in place. I assume that it (the part w/wiring) has broken off. Thanks, Gary.
peakbagger
360
northern nh
Any chance you can get at by removing the defrost outlet?. Getting to behind the dash is major project and PITA due to the front end loader as you need to do from the outside under the hood. There is fresh air and defroster duct work in the way that has be removed.
