Found this Cummins 6cta 8.3 spec spec sheet
datadawg
Bucks County, PA
I wonder how much difference this spec (fire engine) has vs. what's installed in our trucks, especially since this spec sheet is dated 1997, and most of m939a2 truck engines are from late 80's to early 90's. Also was curious to see they list fuel burn of roughly 13 gph. That would mean at steady 55 mph, you're only getting around 4 mpg. I think most feedback I've seen recounting long trips claim fuel economy was 8 to 10 mpg.
WillWagner
2,761
Monrovia, Ca.
"Also was curious to see they list fuel burn of roughly 13 gph. That would mean at steady 55 mph, you're only getting around 4 mpg. I think most feedback I've seen recounting long trips claim fuel economy was 8 to 10 mpg."
Because it is industrial and a fire pump. Automotive, Industrial, Construction and Marine are all different animals. If someone posts an engine s/n, I can find the spec sheet
WV New Guy
Berkeley Springs WV
The ones I have seen are for fixed facility fire protection so if a sprinkler head goes off in say an aircraft hanger the 8.3 would power up automatically and pump water thru piping .
We have 4 pumps set up like this where I work when it turns on to supply water I've never looked at the rpms but they run pretty close to wide open supplying over 1200 gallons a minute. I will have to see what rpms they run at when tripped. I have also seen some newer 8.3 Cummins in actual fire apparatus I will attempt to get pics of both Wednesday when I return to work.
74M35A2
330
Livonia, MI
Not correct, because the truck traveling at 55mph is not requiring all of the engine's power to do so.
