What is the distance that the frame is extended down when using m105 springs and mounts when bobbing or making 4x4. You can see a bolt at about 4" from the bottom on the 5" trailer frame.
I dont want want the mount bolt in line with the frame flange, so could go 5" or 3". I want to sit slightly rear high but I'm concerned it will be too high.
Which do I go, 3 or 5?
Im having a 1/4" plate 8' long bent to an L to lap the side of the frame and really want to get it right.
