chmee
- 0
- 0
- northern, wi
I purchased a 1985 M1009 from an online auction. The fuse block is melted just above the flasher located in the lower rigt of the block. Also the turn signal lever only clicks down (left) 1 position and will not click up (right) at all. The headlights and flashers do not work at all. The glow plug light comes on, and shuts off after warming. The engine will turn over, but not start. I had to use a little ether to get it started in order to load it on the trailer.
My plan is to replace the fuse block with a new one and the turn signal lever switch as well. Could the melted fuse block be the problem that prevents the enine from starting? I am also concerned that whatever melted the fuse block may do so again if I am unable to determine the initial cause.
Any thoughts or suggestions?
