Fried my Generator...can I fix it ?
acesneights1
21
20
CT
Fried my Alternator...can I fix it ?
I think I fried the voltage regulator. is it serviceable ? Any idea where to get one ?
I was changing the rats nest in the battery box and I screwed up and hooked the batts up backwards and I saw a quick spark and now it does not charge.
NDT
6,305
Camp Wood/LC, TX
Assuming you are talking about the 60 amp unit in your deuce, reverse polarity tends to blow all the rectifier diodes. More or less unrepairable.
acesneights1
21
20
CT
I took it off tonight. Local Auto electric shop said they can rebuild it most likely. He is somewhat familar as he does alot of heavy equipment and truck stuff.
1,175
It is actually an Alternator.
acesneights1
21
20
CT
I may talk to my Alt guy and see if we can come up with something else. This thing is alot of money and useless wieght IMHO for the piddly 60amps it puts out. I could save more than half the weight with a little fab and a powerline.
swbradley1
Modertator
1,689
Dayton, OH
I put a civy alternator in one of my trucks and have the parts to do my M809 5-ton.
It tested at around 80A.
acesneights1
21
20
CT
Yeah from what I read I think the Delco one is a 21si or 24si IIRC. I'm not real fond of Delco Alts though. If I can stay with a Leece Neville, I'd like to. that is just my preference from being a Truck Mechanic/owner. Had much better luck over the years with the LN's. I saw some 140 amp LN's that looked like they would need little modification to work and in the 250$ price range. I can live with that.
acesneights1
21
20
CT
FWIW maybe this is old news but parts are no longer made nor is the alternator.
Kenny,
No we have no replacement parts
Best regards,
Customer Resource Representative/Call Center
Paula Parry
Ph# 866-288-9853
FX# 585-492-8811
pparry@prestolite.com
[HR][/HR]
Sent: Wednesday, January 21, 2015 9:51 PM
To: Parry, Paula
Subject: Re: Need replacement part number
Paula,
Thank you. Are parts still available for it ? I need a voltage regulator.
Kenny
----- Original Message -----
To: '
Sent: Wednesday, January 21, 2015 8:41 AM
Subject: FW: Need replacement part number
Kenny,
The alternator was AMA-3002AE and superseded to the AMA-5104UT which was discontinued in “2006” with no replacement
Best regards
Paula Parry
Ph# 866-288-9853
FX# 585-492-8811
[HR][/HR]
Sent: Wednesday, January 21, 2015 8:00 AM
To: Byrd, Frank; Byrd, Frank; Davis, Mike; Fitzgerald, Daryl; Jett, Marion; Parry, Paula; Timerman, Mark
RJ Haberer
Systems Analyst
rhaberer@prestolite.com
Prestolite Electric Incorporated
46200 Port Street
Plymouth, MI 48170
734.582.7217 Phone
585.687.8730 Mobile
www.prestolite.com
Sent: Tuesday, January 20, 2015 6:40 PM
To: info
Subject: Need replacement part number
Hello,
I have a Leece Neville Alternator(it says generator but I believe it is an alternator) from a 1981 AM General M35a2c Deuce and a half 2.5 ton truck
It is 60 amp and the mount it about 7 1/4 inches long. I can find no usable part numbers on it.
Thank you,
[HR][/HR]
1,175
The manufacturer may not have parts, but distributors/vendors do.
