Front Composite Lights
Cdub
New Milford, NJ
I just changed out the front composite light on the drivers side front fender.
The turn signal works just fine just as it did before and so does the BO light.
I don’t know what the other bulb is for though.
IF;
bulb 6 ???? – not working
bulb 7 is for the turn signal - working
bulb 8 is for the BO light - working
then what does 6 do……..??.......mine doesn’t come on at all. Or do I have the
light switch in the improper position for it to work.
Thanks,
C’dub
Barrman
1,760
Giddings, Texas
You need to have the head lights on and then turn the dash light control switch down to "park". The headlights will go out and the top bulb in the fender mounted lights will come on to match the running lights already on at the rear of the truck.
Cdub
New Milford, NJ
OUTSTANDING…….!!
Thank you guys, I never really knew how the parking lights worked any way. All the lights are in proper working order and so is the switch.
Thank You,
C’dub
