ems4ty
- 0
- 0
- restricted/ca
Heres the problem. I just replaced both my fuel sending unit and fuel gauge and can't get it to work properly. I've already replaced the wiring and checked the grounding. Furthermore, I connected the sending unit to the gauge and jumped a ground wire as well. When the sending unit is set to full, the gauge shows full, however when I move the sending unit to empty, the gauge shows beyond full and pegs.
If I connect the guages sending unit terminal to ground, the gauge reads empty.
I ohmed out the sending unit and found that the unit reads 30 Ohms when full and 245 Ohms when empty.
The gauge responds to 30 Ohms Full and 0 Ohms empty.
What needs to be replaced, the guage or the sending unit? Both of these that are in the truck now are brand new and it appears that these are mis-matched.
The truck in question is a 1953 Reo M35 with a OA331 Gasser Motor.
The sending unit has the following numbers stamped on top of it:
4393286
19207S0CN12298209
57733
Thanks for the help.
Tyler
4393286
19207S0CN12298209
57733
Tyler
