Jon Walker
- 1
- 6
- Cedar City, Utah
My truck has had all of the fuel lines replaced, the tank dropped and cleaned, new filters, new water fuel separator, and a new air vent line.
The problem I am having is that I can run at WOT for a brief interval and then the engine stops reving and idles while the truck downshifts and slows down. After coming to a stop for a few seconds the truck will run at wide open throttle again. No white smoke.
I suspect that the fuel filter is being sucked dry because the fuel pressure relief valve has failed. When the filter fills back up it works again until it is empty. I am having trouble locating the fuel pressure relief valve. Have any of you had this problem? Is the valve behind the governor?
The problem still exists after an hour of driving but it seems less frequent. When first starting to drive I can only go WOT for 3-5 seconds. After an hour or so I can go WOT for 1-5 minutes.
Thanks!
Thanks!
