Fuel pump not pumping
rwh64
Wallingford Ct
I am a very inactive member but often visit this site forthe wealth of information it provides. I have spent hours going throughthe technical manuals looking for details on the fuel pump for my 68 Kaiser 5ton multi fuel. The pump runs but will not pump the fuel. Whenremoved I can see the impeller. My question is, should there be a coverover the impeller? I do not know how else the fuel would move up thetubing. Any help would be appreciated.
poppop
39
Brooklet, Ga
Yes there is a cover and it is fairly common for them to fall off. It is in the bottom of the tank. There are several old threads discussing this problem but I am not good with search, maybe you can find them. I think some members were able to re-install the cover and fasten it some way.
rwh64
Wallingford Ct
Thank you very much for the quick replies. I am headed out to go fishing in the bottom of the tank. I need to hear this thing run to give me the motivation to keep spending money on it. Thanks again.
1,177
There is more than a cover. There will be multiple pieces that make up the pump body, then the cover.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Well, might be. I have seen some that have stacked disks to make the fuel "vortex" others it is one piece.
rwh64
Wallingford Ct
Went fishing, of course there had to be Half a tank of fuel to dig threw. Found the shims mentioned and the end cap. Put it all together and she fired right up. These things are amazing, sat for almost 5 years and fired up after about 15 seconds of cranking. I zip tied the end of the pump, hope that helps keep it together. Thanks again for the help, always great advice given here.
Rifleman
HOT Arizona
I think a better idea then nylon zip ties would be to safety wire the bolts, if the heads of the bolts are not drilled you can cross drill them pretty easy, once safety wired you never have to worry about them falling off again.
