stationjj
- 1
- 18
- Middle Tennessee
I think the solenoid on my IP is going bad?
I have a problem where the engine won't shut down after you turn the engine off.
From I can determine the gp system is in good shape, and is operating as normal. The -20 TM talks about the ground wire to the ignition, but I don't think that's it. The IP was replaced by the previous owner in early 2012.
I can force a shutdown by pulling pink wire to the IP solenoid. I have power on pink wire with engine running as normal. With the key off no power normal as well. I cleaned the connector. This leads me to think the IP solenoid is bad.
Can you replace the solenoid without pulling the whole IP? I suspect you can? Not sure.
What is a good source for a replacement? I looked at a few sites, but I am not sure exactly sure what I am asking for?
This is new to me. I am no mechanic by trade, but I am trying to learn. Is my thinking on this wrong?
Thank You,
stationjj
Thank You,
stationjj
