Fuel Treatment
Dock Rocker
72
Jackson ms
I know this topic has been beaten to death in different sub forums but I am asking this specific to the hmmwv.
I have had a few different diesel engines over the years and some needed more lubrication in the fuel system than others.
I know the multi fuel guys just dump some ATF, 2stroke oil, or motor oil in but I don't think that's a great idea for a 6.2.
What if anything are you guys using as fuel treatment? I use my truck pretty regular so I don't think algae will be an issue but who knows.
What say the group?
nickd
36
Newport, Delaware
I add a half quart of transmission fluid to a full tank of fuel. Trans fluid is a great cleaning agent and a high quality lubricant for the fuel pump.
Retiredwarhorses
4,144
Brentwood, Calif
Standadyne makes there own additive, it's a Cetane booster and lubricant, something you won't get from ATF is the Cetane boost...kinda like octane booster for a gas engine.
i buy it by the case.....
papakb
1,184
San Jose, Ca
I've used an addative called D2 for years. When I was first introduced to it I put the recommended dose into the tank and there was a noticable decrease in the sound of the fuel system operation.
DatGuyC
22
Essex, Maryland
http://www.dieselbombers.com/alternative-fuels-additives-fluids/60627-using-atf-tank-2.html
Looks like some people say its fine, others say it doesn't do anything or could hurt your motor. I plan on running some 2 stroke oil in the tank since it was designed to lube and be burned. Its also cheaper than buying ATF.
http://www.dieselbombers.com/alternative-fuels-additives-fluids/953-2-stroke-oil-thread.html
