Fueling Problem
psd350
new braunfels texas
Hello I have an m109 with a ldt465 my problem is that at above 2000 rpm in 4th and 5th gear the engine seems to want to die and then it will catch back up again and keep doing it it seems to be starving for fuel any help will be greatly appreciated thanks!!!
Earth
Corinth Vermont
Absolutely change the filters, but don't rule out air leakage as well. Check all the fuel lines for possible leaks. Just a tweak here or there can make a difference.
jatonka
87
Ephratah, New York
Also, be sure in tank pump is pumping through the primary and secondary filters. Sound means it runs, fuel flowing means it pumps. Also, a clogged air filter is no help, clean it regularly or replace. Earth also has a very good point, inspect and tighten all fuel line connections. Best of luck, JT
