Geared Hub Leaking
drowens1
Oklahoma City, OK
My right rear geared hub is leaking. I would like to know if anyone knows where to find a mechanical schematic of the components so that I can figure out what I need to get it stopped. I've looked at the tech manuals but I don't see anything that gives anything except what grease to use and where to put it.
Bulldogger
585
Quantico VA
Seals often give up after several years, I’ve replaced several of mine and other friend’s. If you haven’t opened and inspected each of your hubs I strongly recommend it. The TM will walk you through it. Check those bearings. If a seal is bad it might let water in to do its dirty work on the bearings. It’s tedious, yes, but it’s straightforward and not hard to do (open and inspect). Do get some Permatex anaerobic sealant as called for in the TM for the inspection door.
If you clean and paint the hubs while you’re down there working on them, it will be easier to work on them the next time. There will be a next time.
Bulldogger
drowens1
Oklahoma City, OK
I'm new at finding tech manuals. I looked in the tech manual section of this forum but I didn't see the tech manual number you mentioned.
Is there some where I can find this manual or am I just not seeing it.
TM-9-2320-280-24P-1
PAGE 555
Has an entire breakout schematic of every part
Sent from my SM-N950U using Tapatalk
