number9
- 0
- 18
- Lexington, KY
I finally used the Geared Lug Wrench this weekend....... and broke it. I had read the PS mag article as well as the Ken-Tool pdf that are posted on this site. Both are geared toward describing how to remove the rear dual nuts - ie. budd nut and the outer lug nut - not specifically JUST the outer lug nut like on the front wheels.
I remembered the section attached below about running the bar handle through both holes and using it to remove the outer lug nuts. What I didn't remember was this was AFTER you break it loose.
I put the short bar handle through both holes and then slid the long tube handle over it for extra leverage and put my back into it. The lug nuts broke loose but it took some doing and a few of them made a really good POP - I suspect now that one of those pops was obviously the "pinion stud" (shoulder bolt) that holds the secondary gear on the wrench body.
Luckily, the threaded portion broke off and I was still able to use the wrench to get the front wheels changed out. This wrench works SLICK and GREAT when used correctly.
I emailed Ken-Tool today with the following.......
ETA - the process in the pics below is the correct way to use the wrench when working on just the outer lug nuts. Let the long tube handle react against the ground and pull on the short bar handle to do the work.
ETA #2 - forgot to include the PS mag pic I was thinking of when I broke the tool.
and here was their response......Hello, I have a Military Surplus version of the TR43 Basic Power Wrench Set - only it came with a 20 1/2" bar handle and a 36" tube handle. I was using it this weekend and the Pinion Stud & Nut broke. I need to purchase a replacement. I see from your parts manual that this should be part # TR48A assuming the design of the tool has not changed from the tool that I have. How do I order a replacement? Also, how do I confirm that the current design of the tool is the same as the tool I have? I have included 3 pictures of the tool.
I measured the shoulder and it IS the same, so if anyone else has this happen, you now know a replacement can be had. I don't have cost for the part yet but will update post when I get it from her tomorrow.See comments from my Engineer, below.
The wrench shown is very old. We are in the 3rd generation of the tool and this is the first generation. I can't be sure of the length of the shoulder of the bolt. The shoulder on our current bolt is 1-61/64 inches. If this size is the same as the shoulder of the broken bolt he can purchase the part. The shoulder is from under the head of the bolt to where the threads start. The part is a TR48A pinion stud.
