I received the equivalent of a GTR43 "power wrench" set from a vendor on ebay on Thursday. I tested it on the front lugs to see what I was up against and it broke them free, no problem, with the 18 inch bar. With 200 lbs of weight, rough calculation puts it somewhere near 900lbs of output force (200lbs x 1.5ft [bar length] x 3 [torque reduction]). For the rear outer lugs, you only have to use the 18" bar, because the inner budd cap socket secures the torquing action against the budd thimbles and prevents them from turning. Switching to the large bar turns the inner budd thimbles after you have loosened the outer nuts.
The pictures show the large bar (in this case, being used as a "reaction bar") digging into the ground on the front wheel because there is no inner budd thimble. Turn the small bar towards the head-lights and they crack loose.
I ended up replacing one of the weather-checked rears with a fresh wheel/tire (I have 12 extras littering the yard). The only difficult part was heaving the new one onto the hub. A brick strategically placed under the new wheel made matters easier.
I really like quality hand tools. There are some other threads here that were essential reading to figure this thing out.![A toast to MV's :beer: :beer:](https://www.steelsoldiers.com/images/smilies/beerchug.gif)
