GEN 1 and GEN 2 lights on
joeyaguirre21
el paso, texas
Back again fellas. Well I was doing the front crankshaft seal a couple days ago while doing that when I was taking off the belts by accident the right alternator hit its bracket and sparked. I finished the seal fixed the eyelid terminal for the alternator, cranked it up and GEN lights inside the cab stay on. Checked the fuses they were fine but still changed with new ones and nothing changed GEN lights are still on. Any ideas?
parklandtrans
Roy, wa
Perform charging system check for alternator output, normally light comes on when voltage is very low or non-existed...also please double check fuses and possibly any in line fuses that may be hidden under electrical tape. Lastly, check for any OEM relays or aftermarket ones installed..let me know what we find...!!!
Bob from Roy, WA
