Gen 1 light staying on after shutdown
86Chev1028
MA
A few days ago after using my 1028, I shut off the truck and all was fine then the gen 1 light came on and even after removing the key would not shut off. I restarted the truck, then shut her down to see if it would come back on. After about 4 seconds or so after shutdown, the light comes back on and won't shut off. I disconnected the batteries to prevent them from draining. I searched for other instances of this problem with no luck, anyone ever hear/experience this???
1,174
First thing I would check is, a good engine ground connection. At the alt, engine to cab or frame. Try adding a jumper wire from a clean spot on the intake to the front bat neg terminal. See if the light goes out.
If that doesn't change anything, rebuild your alt.
Warthog
231
OKC, OK
A bad rectifier in the alternator will cause a simular problem.
Follow Dogheads advice, check the connections and order a rebuld kit.
86Chev1028
MA
I'll give the jumper trick a go, I had wanted to get the alternators rebuilt since I bought the truck a little more than a year ago so if it doesn't go out, no biggie, time for a rebuild. I want to keep this beaut running strong for a long time. Thanks for the replies!
86Chev1028
MA
So I had a local shop rebuild the alternators. $115 a piece, guess that's around mid-range from what I've seen on here. They were done the same day too, can't complain about that. I would've rather gave it a go rebuilding it myself but don't quite have the time to wait for a kit to come in and take my time with rebuilding it at the moment.
I have two extras that came with the truck, so it'd be a good winter project to rebuild one of those. Nothing like knowing you have a good working spare on hand. Now some new belts and let her work!
jholler
Jonesboro, AR
My 1009 started doing this this morning, but the oil light also comes on after shutdown. I HOPE this means nothing but a grounding problem....
1,174
A bad ground is just one possibility. More likely there is an internal issue with your alt. Here's a snippet from the AC Delco manual.
86Chev1028
MA
Got the rebuilt alts in today along with all new belts and two refurbished group 31's from Interstate, running like a top once again! Next job- replace a muffler and get the revolving light on the roof for plowing :D
Warthog
231
OKC, OK
Good job!!! [thumbzup]
Did the rebuild shop happen to say what the problem was?
86Chev1028
MA
Thanks! I asked them but they said since they were replacing all the replaceable parts that they just ripped everything out and put new stuff in so didn't bother to check.
