Gen 2 light?
sixb
West Jordan UT
well I rebuilt both alternators and now the gen 2 light comes on and off every now and again. The charge gauge is in full green. What gives?
1,174
Did you personally rebuild them, or have someone else do it. What was done to rebuild them?
Are your belts new and tight?
You could swap the 2 alternators positions and see if the problem moves to Alt 1, to see if your alt is still bad, or you can follow the troubleshooting guide in the TM.
If indeed your alts are both good, I would guess you have a bad connection or a bad battery.
91W350
57
Salina, Kansas
One of mine did that shortly after a rebuild, lost a diode. Did not take much to fix, just had a little double work that had to be done.
sixb
West Jordan UT
had a local shop do it.
yes and yes
I plan on swaping them after work.
batteries checked good at autozone for what thats worth, the stickers on them say March of 03
TyJustice
Denver
My Gen 2 light also likes to keep me company and can become annoying at night. The truck charges fine and I have checked all connections with no success.
How does one go about changing out the diode? If that is in case my problem.
1,174
The diode trio is inside the alt. It needs to be completely dissasembled to replace it. If your in there, you may as well replace everything inside(only about $40).
Radioshop
Miami, FL
I might have to rebuild an alternator soon. I read a tutorial online about how to do a Delco alternator. It didn't look like rocket science. What has stopped me is finding a source for parts and I'm not sure if the parts in the alternator are special. Most of the sites I've seen for parts assume you know what you want. I know it's a Delco 100 amp, but it's also isolated ground, so does that make for any special parts?
1,174
No special parts need to be purchased to rebuild it, the plastic insulators(keeps it isolated) are reused.
The alternator is a 100 amp, delco 27si, type 200, it uses type 100 bearings . That's all you need to know to order the internals to rebuild it. I like to buy a low speed and low voltage triggered regulator.
There a lots of online places to order the parts from.
acesneights1
21
20
CT
I thought the drivers side alt wasn't isolated, only the pass side ? Am I incorrect ? They are both the same ?
1,174
The cucv is built with 2 identical isolated ground alternators. The drivers side(alt1), does not need to be isolated. They simply did this, to not need to stock 2 different alternators. The passenger side(alt2) does need to be isolated from ground.
Midnight Rider
Sesser, IL
My Gen 2 light comes on/off occasionally as well. But usually only after I've been running awhile and then idled down, driving through town for example.
It's been doing that since I bought it and I know the previous owner replaced the belt for that alt. I guess I'll look into rebuilding it.
Radioshop
Miami, FL
That's what I needed to know! Thanks!
sixb
West Jordan UT
I still haven't swapped them yet, I wan't to call the company who rebuilt them first to see if they are both isolated grounded alternators.
