AllenEM
- 0
- 0
- Allen, Oklahoma
is it ok to put early 6.2 hmvee glow plugs in a m1009? are they 12v or 24v?
pre glow system? what is that. If I change the connect to the round and remove the restor pack and run 24 volts to the glows wouldn't that work?To our experiance here you can use any HUMMVEE glow plugs. They are all 24 Volts. You have to modify the connecting harness. HUMMVE glow plugs have a regulator built in, M1009 glow plugs not, this stuff is in the glow plug control, as long as it works (Never over 120000 miles to European experiance.)
24V glow plugs are a considerable change, if you change the pre glow sysrtm as well. The registor is obsolute, the harness should be home made for the 12/2.8 Volt stuff is unuseable. The pre glow module than also is for the trash.
Try hard!
Wolf
thats great to hear. now make sure you keep the as cool as you can. don't overheat them. about once a month take your ohm meter and check them all too see if you have 1 going bad. you will notice is will slowly get harder to start. thats the way my hmmwv works.HUMVEE glow plugs are working great now that i have a good relay. push the button for 5-7 sec and she fires right up.
