glow plug questions
redneck785
bainbridge, ny
i have been having glow plug problems, I replaced glow plugs, and relay and am installing a manual glow plug switch. My question in how long do i need to fire glow plugs without harming or exploding them?
Mg84648
Cumming, Ga
With mine I just hold the button until my wait light goes out and count 5 more mississippi's then crank it. Starts on the first crank most of the time. Not sure which portions of your card are inop so this may not apply to your situation.
1,176
Simple answer, 10-12 seconds.
Step by step troubleshooting is covered in the -20 TM.
All of the components are available new.
1,176
Also, what part number relay did you install.
cucvrus
10,322
Jonestown Pennsylvania
I count to 500 cause that is about what it will cost if you overheat the glow plugs and just 1 glow plug bulges and breaks off inside the combustion chamber or you can't get it out of the head. I know it is the worst case scenario. But why not fix it the right way like other members have suggested. What if someone else borrows it or just try's to move it for you and over glows it. Its real it does happen. It is not worth it. And as a gentlemen I agree to disagree with anyone that says it don't and can't. Stop the cobbling of things and fix it the way it was intended. My opinion again. Oh yea you can R & R the heads yourself for about $300. in parts. And it is a fun job. Not worth the risk. Please fix it right the first time. All the parts are still available.
Westech
CPL
6,104
207
cow farts, Wisconsin
I had to replace every inch of my High speed M1008's glow plug control system (control car harness also) and it cost me around 250 bucks (glow plugs, control card, Wiring harness, firewall relay)
The truck starts every time and I dont have a cobbled wire.
2 cents
TexAndy
15
Bee County, Texas
If you look around, a few people have repaired their glow plug control cards. According to them, it's only 3 components that cause 90% of the failures.
MarcusOReallyus
816
Virginia
Even better, you can get a brand new one, with improvements over the original, from SS member antennaclimber, for 85 bucks.
blzrgb
mississippi
My 1008 is also having problems. Turn the switch on and nothing happens at all. No wait light, no clicks or anything.
Replaced all glow plugs and all 8 were blown. Still nothing. Replaced glow plug card. Still nothing.
BUT, I can give the two blue wires on the relay a ground with a jumper wire and the wait light works and new glow plugs heat up. The truck will then start. Could it be a bad relay or temp sensor or Both ? My temp sensor has the single probe.
Having trouble finding replacements. If that's even my problem.
rsh4364
15
greensprings ,ohio
My 1009 is manual gp only,was that way when I got it,I glow for 15 secs. when warm out,20 when its colder out and up to 30 secs.when its 0 out.Have 60G plugs,no swellers yet.24 volt starter,everything else 12volt including gps.
1,176
You can keep throwing parts at it or you can properly diagnose it using the TM.
Westech
CPL
6,104
207
Or just replace the whole shootin works for 175 bucks and be done with it.
plugs, card, relay and temp sender.
Thats why I say to replace the glow plugs and relay every other year regardless.
For 75 bucks its cheap insurance to not burn up cards and have a good starting CUCV.
