I have noticed that my M1009 does not always want to start easily when it is cold, but this morning it would not start at all. According to the forecast is was supposed to be 25-30 degrees this morning. After multiple attempts to get her started I decided to give it a tiny squirt of ether from the extra bottle for the deuce. I waited till the glow plug light went out, and then cranked her over. She started right up.
Do the glow plugs turn off when the "Wait" light goes off?
Is there a easy way to disable the glow plugs when you need to use ether to start?
Are glow plugs as effective as ether?
I realize that my glow plug system may not be 100% as I have not done anything with it, but it does improve starting normally. I also realize that ether and glow plugs are not compatible at the same time.
