Goodyear 14.00x20
Rogarner
Rockmart GA
I've got a m817 5ton dumptruck that I'm wanting to singles out and a guy near me has 14.00x20 on wheels that came off the newer 900 series truck not sure which one. Will those wheel bolt up on my truck? I'm going to try to post some pics. Thanks Bob
Monkeyboyarmy
194
Kingsville,Oh.
Should bolt right up. You will need the standard front lug nuts to install the rear wheels as you won't be using the inner and outer thimble nuts for the dual wheels.
lindsey97
wynnewood, oklahoma
Yes, that is a 5 ton combat rim. check your date codes on the tires to see how old they are.
Specs for the front lug nuts: 3/4-16 thread, nut is 7/8" thick. 1.5" outer hex.
At Orielly's the part # were: BWP M125 for left hand thread, and BWP M124 for right hand thread. 20 additional needed of each thread to single out a truck. These are the same as the front lug nuts on a M939 series 5 ton.
