look a little closer
I'm trying to figure out how to get my front hubs off...
Anybody got a picture of the special wrench....or is there a size on it?
I think what might have you stumped is the outer retainer clip.....very thin, you need to use an all to get the end of it started coming out....
I know it may sound bad but I always go to the junk yard for spindle's/bearings/axles w/ good joint/and the little clips for axle and stuff.
Maybe i'm lucky to have a large yard near me...I can buy a hole corner of the truck with the parts listed for less than 50 bucks, and BTW I never mess with pressing in/out ball joints, 44 and corporate are the same from knuckle out so I get knuckle too.
I have changed and broken countless axle joints in 44/10 bolt and come to the conclusion that it's far easier to change out the whole axle and the stock spicer joints are the strongest i've ever run.
because your running corporate front in that you could put large hub(extenal hub rotors (eight lug) and run external hubs...I prefer them to internals on the 44/corporate....then a 14 bolt and your 3/4 ton with only 1 axle swap, just in case you want bang for the buck since your replacing everything anyway!
I dont know how it is where you live, here I could change/ rebuild to any 1/2...3/4 ton combo I can dream up for less than 250.00
Hope the info helped
