Got the M1008 Home
rumplecat
221
North West Arkansas
Picked her up at Camp Robinson in North Little Rock, two new batteries, checked the fluids and a little gas to prime her and cranked right up. Only real need I notice right off is that one of the base mechanics liked the tires and I ended up with his old set of tires and wheels and no spare, but other than that a good straight truck!
I got about ten miles out of Little Rock with I started to smell antifreeze, another 2-3 minutes my windshield was fogging up from the inside then I saw a few drops of water on the passenger side floorboard. Stopped and sure enough I had water leaking out of the bottom of the heater box just outside the firewall. Stopped and picked up a couple of gallons of distilled water and limped to the cabin driving 45-50. I leaked maybe four gallons over the 85 mile trip, I am sup prized there is no shutoff for the engine water to the heater core . One other strange thing did happen, when I switched on the lights the horn would blow, I pulled the wire to it and all is fine except I don't have a horn or any high-beams, it also looks like someone tried to adjust the head lights a little too much it looks like both of the top adjusting screws are stripped.
So now a little maintenance and I need to find a hitch that doesn't look to bad on it!
ralbelt
9
West Warwick, R.I.
You can pick up a hose connector 3/4 to 5/8 and disconnect the heater hoses at the fire wall and connect them together, you won't have heat, but no leak.
rumplecat
221
North West Arkansas
My brother had that idea as well but I will need the heater, I just need to get it apart to see what is leaking, I hope just a loose connection? I also noticed both alternators belts were a little loose, tightened them up now my gen 2 light is on, so I guess I will loosen them up a little to see what happens?
ralbelt
9
West Warwick, R.I.
I have mine by passed for now, not a bad leak more of a smell, I will either have to hook it up again or fix it as winter is coming. It seems to come out by taking off 3 or 4 nuts on the fire wall and one behind the ashtray. Said not to be a bad job, once out i'll take it to a rad shop as the new ones are said to be of low quality.
rumplecat
221
North West Arkansas
I have seen them for sale for under $40, but I think you may be right on the quality, it is hard to beat OEM stuff, I may hit up some junkyards.
