Half shaft leaking
Dpas1973
13
New Jersey
Since I’m new to this I noticed the rear passenger side leaking today what parts are needed to fix this?
rcamacho
827
Bainbridge Island Wa
Looks like the hub input seal.
Follow the TM to remove the shaft and replace the seal.
If the seal is leaking I recommend you do both seals at the same time it’s a larger job it probably well worth it. E.g. spindle hub seal as well.
If you do do the spindle hub seal make sure you get the bearing adjustment correct as well as the locking tabs engaged properly
Dpas1973
13
New Jersey
You have a link to the tm on replacing that ?
Ajax MD
1,414
Mayo, MD
Dpas1973
13
New Jersey
The links don’t open the pages
papakb
1,184
San Jose, Ca
TM 9 2320-280-20-2 section 6 has the complete proceedure for replacing the hub seals. Download it if you don't have it and you can print out pages 6.13 to take into the shop.
