- 849
- 1,740
- 93
- N. Central Idaho
I've finished my idler gear repair, have the oil pan, water pump, etc. all installed. Now on to the harmonic balancer. Issue is my puller/ installer does not have the correct adapter for the internal threads on the crank. It's a 1"-15 TPI thread and mine only goes up to about 7/8". I've been unable to find an adapter or even a set with that thread. I've searched SS and the internet especially the companies that claim to specialize in diesel engines. I have not heated the balance as per the TM yet, trying to get all my duck in a row first, but it won't even start to fit over the crank.
After heating is it likely to slip over enough to use the bolt to push it the rest of the way?
Any help appreciated.
