Head light switch replacement (headlights will not turn on)
MGVFD
24
Texas
Hello, I replaced the old digital headlight switch after it failed. I use a manual three lever switch. When I turn the lights on the running lights/ tail lights come on but no headlights? Are the headlights on a separate fuse?
MGVFD
24
Texas
Ok I have been searching and I found this thread.
I will check K7/K8.
Ronmar
7,422
Port angeles wa
A0 lighting ckt. Basically the same throughout the versions, with the exception of the brake ckt. On the A0 the pedal pressure switches provide a ground, in the A1s they changed to the switches providing DC power…
MGVFD
24
Texas
I have a question, When I changed the switch to the three lever switch there was no place for the ground wire. Could this be causing the issue?
Ronmar
7,422
Port angeles wa
Probably not. The button lights switch is a powered electronic control device that consumes power so requires a return/ground path for its operating current to flow thru. The 3 lever is simply electrical contacts, so no ground required…
