84cucv1ton
- 0
- 36
- New Jersey
no idea what im missing. ideas?? thanks
Work the switch a bit. It should click.Questions: When I pull back on the wiper lever, the rod moves and the switch actuates, but there's no "click". Is there supposed to be one? Is it possible that the hi beam in both headlights is burned out?
When you say "switch" do you mean the wiper lever, or the actual switch located down on the steering column? And, is there supposed to be a "click"? If so, does the click come from down at the switch or up at the wiper lever?You needed to work that switch more. That's all.
