help cabin harness problem!
1984redcucv
Hi guys, I recently purchased a 84 m1009 and everything was going well till I decided to take apart the dash to clean it. Does anyone know the the order of the cabin harness? I found a thread somewhere else and this is the order its giving me.
1. Bright indicator
2.Dash illumination light
3.Oil Pressure low light
4. 4x4 indicator
5. Ground for dash lights on the left
6. alternator #2 (truck had 2 alternators)
7. Also goes to Alternator #2 - Ground maybe
8. Alternator #1
9. Ground for lights
10. Left turn indicator
11. Right turn indicator
12.Ground
13. Light below speedo, left side
14. Light below speedo, right side
15. light below fuel level, left side
16. also light below fuel level, left side
17. light below fuel level, right side - low coolant
18. Fuel Gauge
I put a tester on it n my #7 is at 25.2 volts all the time. Is that suppose to be at 25.2 volts if its a ground?
