help, I need to find info on injector pumps
lenz1079
Lacon, IL
my 1971 duece blew out the seat ring on the bleeder valve of the injector pump and i need another brass ring seat. a nickel part, my kingdom for a nickel part. also i was wondering where to find the exploded view or tech manual for the injector pump. Any info or help would be apprciated
m-35tom
222
eldersburg maryland
there is not a bleeder valve on the pump, so i wonder what you are referring to? the few ports on the pump do not use any type of sealing washer as the pressure is too high. if it had a brass or copper washer that may explain why it blew out.
m-35tom
222
eldersburg maryland
that is the fuel delivery check valve. very high pressures here, no gasket, torque it to 40-45 ft lbs. loosen and retorque 3 times total. if it still leaks replace ip head. this fitting is matched to the ip head, do not swap from any other ip head.
lenz1079
Lacon, IL
OK, after following your information, and thank you thank you, survey shows that the bolt and hole are shot!. Now:
1st Question..... what is the NIIN for an injector pump Head, i have acess to the govt and their parts.
2nd Q.... if i cant get it from the military, where else and maybe a cost estimate.
you guys that answered me have helped alot, again thank you. i guess i know why my free & running truck was classified as H7. if i can look for any parts for Bjorn or tom let me know, ill try my best
1,179
American Bosch HD90100A hydraulic head
NSN 2910008287176
I believe the gov. pays $1076 for one
pm sent
