joesco
- 1
- 18
- Hampstead, NH
First big public thanks to Carl from NH and Speddom for all the help thus far.
I bit the bullet and had to purchase a rebuilt Model 50 IP. I was told by the shop that the rebuilt IP does not have a timing button and I should remove the button from the old IP and install it in the rebuilt unit. The old IP was so gummed up that it two hours to remove the tappet. The rebuilt pump took about 5 minutes! See Pics!
Some additional background first. Both IP's are marked with the number (button code code) 47 which was found under the tappet. In addition, on the flanges, the old IP has a number 1 on the flange, which I believe is button code(???), the rebuilt unit has a number 13.
On the other side of the flanges, the old IP has a Port Closing Dimension (PC) of 1.088 and the new IP shows a PC of 1.090. Pretty darn close??? So my questions...
Can I assume I can reuse the old IP's timing button?
If so, how in the heck do I remove the dang button? I don't see a retainer ring.
When you look at both units, side by side and not knowing what a timing button looks like, does the new unit have one? (See pics)
Last question... If I figure out how to remove the old timing button, can I assume I can use timing Method 1?
Thanks folks!!!
Thanks folks!!!
