Help me ID this deuce
desertfish
Hi guys
Ok on my way home i saw a deuce behind a old general store and it looks
strange because it has a can air filter on the fender not a big one like on the 5 ton and it was on the pass side also it had recessed tail lites behind the bed panel under the tail gate. I also noticed that it seemed to have alot of lug nuts like more than 8 it had a hard top and a drop side bed.
so what do you think it is?
M1075
Oklahoma City
nopics
I've always wanted to use that one!
What makes you think deuce? If it has more than 8 lug nuts (ie. 10) then I would guess 5 ton.
desertfish
The 5 ton trucks that I have seen have a big a$$ air filter can on the driver side this one has a small one on the other side. maybe it's a older model?
Take a look at the pics below. One has filter on driver side, one on passenger side.
Courtesy of: http://www.m201.de/armytrucks/armytrucks.html(Btw - great ref site, lots of pics :D)
First pic below is likely what you've spotted: Older series 5-ton - m39 series or G744 series ("-A2" LDS 465 multifuel -or- "-A1" Mack ENDT 673 Diesel) Gas Models (like mine) had no external filter housing - had oil bath filter under the hood)
The second picture is probably what you are used to seeing - 800 series (NHC-250 Cummins)
