You do not put your o ring in until after the wheel is seated deep enough in the wheel. I dunno how that happened like that with a runflat unless you tried pulling thru with the beadlock studs.View attachment 726397View attachment 726398
Look what happen on the 2nd pic, the run flat got between the 2 pc wheel and it leak, make sure and tighten up your bolts before you put air in the tire ....
