Help with M925 pneumatic electric brake controller installation.
ida34
33
Dexter, MI
I have a need to pull an electric brake equipment trailer. I am using a pneumatic controller that is actuated by tying it into the brake circuit. I then plan to run the 12 volt trailer on an independent battery. Basically I need to know where to tap for the line to the controller. Hydraulic is pretty easy and I putting an old style hydraulic brake controller on my Deuce. All the different air lines running all over the place has me a bit overwhelmed. I hope to tap off at the brake pedal as it would be the shortest run. Which line would I tap? I see 2 lines coming in and 2 lines coming out. Is there an extra port on the brake pedal valve I can use instead of tapping the line? I see several port plugs. If I can't figure it out I will just run the trailer brake line back and tap it as far forward as I can. My truck is an abs truck as I am sure most are so I do not want to mess with anything that will screw up the abs. Any help is appreciated.
Chuck
Suprman
696
Stratford/Connecticut
Cant you use an electric controller that taps off a brake light? You can use a relay and tap 12v between the batteries for actuation if it wont take a 24v input. I dont see how you would use a separate battery for trailer lights control unless you used a relay for each function.
ida34
33
Dexter, MI
I am not using 12 volts for the trailer lights. Only the trailer brakes so using the pneumatic controller eliminates using any relays and gives a more accurate proportional brake control than the electric on or off triggering of the electric controllers. I am using 12v-24v led lights on the trailer and running them through a home make adapter between the military trailer connection and the 7 pin rv plug I am using. The 12 volt battery will only run the brakes. Basically, I am adding two wires running back to the trailer adapter and nothing else is changing on the truck. I can then move the adapter between the Deuce and the 5 ton. I appreciate the input but the pneumatic controller is bought and will be used. I was just hoping for some input from guys that may be more experienced with air brakes than I am.
Chuck
Jason O
Lebanon PA
The foot valve (pedal) has extra outlets for applied brake pressure. It shouldnt make a difference whether you use the primary or secondary air circuit. If I'm remembering correctly they are 1/4 NPT plugs, removed with an allen wrench.
Swamp Donkey
The Engineer
120
Gray, GA
I can't answer your questions but I do happen to have some pictures handy of one that is removed. Maybe it'll help someone point out which ones need to be used.
Left Side
Right Side
Back Side
ida34
33
Dexter, MI
Good to see you stopping in Chuck!
Hope to see you at Findlay this year.
Hi Gimpy. You know I will be there. I traded the HMMWV for a halftrack. It will not make it to Findley this year but will next year. The trailer stuff is go haul the track. I need to pull the injectors on the five ton before I start using it for the tow vehicle. Right now my F350 and Deuce will have to do. I am getting fuel in my oil on the five ton and hope it is only injector orings.
I still check on the place but have not had too much time to do much online discussion.
Chuck
