I took the deuce to Iowa and back pulling my M725 there for the FE and first off the tank fuel pump went out but it managed to run and made it home. I changed the pump out and fixed that part.
the transfer case started puking oil out the input and front output seals. does anyone know waht the part #'s are or where you can pick them up at?
Ive changed the secondary filters and gaskets but cant find the part #'s for the gasket on the primary filter. is there such a creature.
Im in the process of putting on a 10 ton? garland winch (off a 5 ton truck) on the front of my deuce and using the hydraulic pump that came with it. my question here is its heavy enough to need power steering now. any clues if you can do this on the older trucks?
I have a 68 M35-A2 with the LDT 465-1C if that would help? :banghead:
