- 14,622
- 4,744
- 113
- Buchanan, GA
Anyone have any idea on how one could install door locks on it?
Thank you! I knew there had to be some civy style door handle. I'll go search for those now!just replace your handle with a off the shelf Freightliner exterior door handle.
I think I came up with a cheaper and easier way. And it'll blend in better than the HET style lock.
http://www.homedepot.com/p/Master-Lock-Flat-Oriented-Padlock-Eyes-1-Pair-60/202324265#.UqhxxOLouE4
Use a pair of these on each door in the jam. I can also just use a cable on the wheel to secure it as well. Then some locks on the battery box and tool boxes. Easier to get a set of padlocks with matching keys that way.
You're right, I forgot about that latch thingy.You don't need a cable on the wheel. Look under the dash at the first right angle box, there is a bracket on a hinge that folds up and you put a padlock right there. as far as locking the doors just run a cable from the inside door handle thru the drain plug (same on both sides) then put a pad lock between the two cables. At shows I just use a motorcycle tie down and do the same thing.
Ryan
Got these in today. I did manage to install them on one door. The holes that were on the doors worked perfectly. And there's several on the door side to allow for adjustment!I think I came up with a cheaper and easier way. And it'll blend in better than the HET style lock.
They're certainly nice, but a little expensive. $40 a hasp vs $2.50 for the setup I listed. The ones I found are a bolt on too, nothing to drill.
Or you could just apply something like this to your windows.Patracy,
Thats why I am presently considering adapting the tactic used by the danish police for the riot control vans. All the windows have been replaced with perspex/polycarbonate panes which means that if someone tries to toss a brick or rock at the window the window will simply take up the pressure and release it in the form of "repelling" the object back at the person that threw it
This item has been discontinuedI think I came up with a cheaper and easier way. And it'll blend in better than the HET style lock.
