High back seat install - driver base question
badgerd
Electronic Jedi
102
65
Chesapeake VA
I’ve got the drivers base and all the brackets but didn’t get the reinforcement plate shown in the MWO. I’ve seen pics of some with it installed and others without. What’s the “right” answer? Opinions?
Thanks!
AAVP7
262
Dortmund, Germany
Without the reinforcement plate, all that holds your seat in the event of a crash are those tiny #10 screws that fix the transverse seat rails to the body. And with the body being comparatively soft aluminium, any strong force on the seat will probably pull those screws right throught the alu body. The reinforcment plates (steel, if I remember correctly) are there to spread the load from the screw heads over a larger area.
I would definitely mount that reinforcement plate. You can easily make them from sheet metal, using the transverse seat rails as a template.
papakb
1,185
San Jose, Ca
When I installed mine the kits weren't available so I made my reinforcing brackets from 1" bar stock aluminum 3/32 thick.
Retiredwarhorses
4,182
Brentwood, Calif
FYI....OEM from the factory does NOT use any sort of backing plate, those Backing plates were only in the MWO kit.
I personally have installed hundreds And don’t use them.
AAVP7
262
Dortmund, Germany
RWH is right (as always (y) ); I just checked my M1045A2 that had high back seats from the factory; and there are no backing plates. My M998 that I refitted the seats by MWO has those plates. Weird....
papakb
1,185
San Jose, Ca
Since the HMMWV forum is known for it's strick adherance to factory configurations :roll: I used 1/4-20 hex head bolts to mount the seat base and the backing plates. I know there are many ways to accomplish something and bickering over plates or no plates, Rivets or screws isn't all that important. What is important is the installation is done in a safe manner.
