Hmmwv / M998 1992 6.2 Water Crossover options?
kfrosty
Belmont, NC
Part # on mine is 23500012 (What I found in another thread was not correct.)
Haven't had any luck finding one of these. Searching for an hour, found a couple of threads where people have had the same problem I did. Bottom bolt was welded to the threads of the crossover. Trying to change the thermostat, bottom bolt how broke.
I'm going to try the part number at some junk yards tomorrow but I have a feeling if they don't find the #, then they'll ask me year, make and model.
I'm wondering if it's the as on an early 1990's 2500 HD or 1995 Hummer H1 6.5? Need to find gaskets as well.
DatGuyC
22
Essex, Maryland
I got mine off ebay. I'm not sure if any civilian crossover will work because it needs the port for the tsu for the glow plug controller and the port for the fan switch.
Retiredwarhorses
4,174
Brentwood, Calif
Water crossovers for HMMWV's are all over sleeze bay...beltfed34 has plenty.
per the TM
12554091 6.5 and 6.5 detuned
23500012 6.2L
kfrosty
Belmont, NC
Thanks. Not finding the 23500012 for my 6.2 on ebay. Are these interchangeable? The only difference I see from the pictures is an threaded hole for a hose fitting that connects to the waterpump. On the 12554091 for the 6.5, it rounds out to the front. On mine it's on the bottom.
Greg89
Seattle, WA
I just bought one from Kascar and one from Eastern Surplus. Both part #23500012. One weird problem I am running into, though, is that the threads in the port for the TSU don't seem correct as the TSU will only screw in about half way. Anybody else have this issue?
DatGuyC
22
Essex, Maryland
The 6.2 hose fitting is on the bottom where the 6.5 is more to the front. I have a 6.5 crossover on my 6.2 and it works fine, though I didnt use a stock hose but just cut some to length. As for the tsu threads it isn't supposed to thread all the way in, it's like a pipe fitting. As long as it doesn't leak it should be fine.
kfrosty
Belmont, NC
Thanks. I'll order a 6.5 and see what happens.
