- 2,975
- 4,356
- 113
- Olympia/WA
So quick search didn't turn up this exact thing I found on my truck.
I knew I had a fuel leak from the top of my tank, directly above the fuel fill inlet. Finally got around to dropping the tank today to take a look at it.
Pretty obviously a drilled hole. No holes in the bed of the truck, so no idea why a hole got drilled in this spot.
As there isn't any risk of cracking or anything like that, I'll probably plug it with some sealant, a bolt, nut, and a couple of washers.
Just wondering if anyone else has come across this before?
